Consumi 1.0 TGI (90 CV) - Topic Ufficiale
Consumi dichiarati e riscontrati divisi per ogni motorizzazione Arona.
jimptsog
LocalitĂ : Greece
Auto: attendo un'Arona
Messaggioda jimptsog » 22/03/2019, 22:06
11.82Ă—100Ă·322=3,67kg/100 km
14Ă—100Ă·370=3.78kg/100 km
Very good
Gigio22
LocalitĂ : Solofra
Messaggioda Gigio22 » 22/03/2019, 22:14
Yes, i hope that mine will do the same. Moreover he got not so much km till now. So it could go better
andrew2110
LocalitĂ : Montegiorgio
Messaggioda andrew2110 » 23/03/2019, 11:47
MNTDVD
fai rifornimento sempre allo stesso distributore?
non vorrei che carichi poco ...magari ha un impianto vecchio...ecc
MNTDVD
LocalitĂ : Udine
Messaggioda MNTDVD » 23/03/2019, 12:15
Ultimamente faccio rifornimento da un nuovo impianto IP e anche con la golf mi sono sempre trovato bene.
Ieri alla fine sono riuscito a fare 289km e ho ancora 40km di autonomia!
Quindi piano piano migliora secondo me!
jimptsog
LocalitĂ : Greece
Messaggioda jimptsog » 23/03/2019, 14:06
MNTDVD...
If it is easy, can you write how many rpm your motor has to 110-120-130 km with 6 speed?
without videos.
MNTDVD
LocalitĂ : Udine
Messaggioda MNTDVD » 23/03/2019, 14:08
Sure,i’ll test it later and tell you the results.
At the moment i can only tell you in 6th gear it has 3400/3500 rpm at 140km/h
jimptsog
LocalitĂ : Greece
Messaggioda jimptsog » 23/03/2019, 14:18
Seat ibiza tgi 2018 model with 5-speed.
122 km has 2650 rpm with 5 speed.
MNTDVD
LocalitĂ : Udine
Messaggioda MNTDVD » 23/03/2019, 22:10
6 Marcia / 6th gear
Velocità / Speed —> Giri/RPM
110 km/h 2750
120 km/h 3000
130 km/h 3250
140 km/h 3500
Messaggioda Hook » 23/03/2019, 22:16
:ontopic:
jimptsog
LocalitĂ : Greece
Messaggioda jimptsog » 23/03/2019, 22:25
Mr Hook It's about fuel consumption...
MNTDVD To have a fuel of 4 kilos you have to forget 140 and 130 km. Only 110 to 120 km
jimptsog
LocalitĂ : Greece
Messaggioda jimptsog » 24/03/2019, 16:18
MNTDVD...
What do you mean in this paragraph? The translation is not good.
MNTDVD
LocalitĂ : Udine
Messaggioda MNTDVD » 24/03/2019, 17:20
I mean that with my new Arona I use to fill it in a new gas station aka IP (Italiana Petroli,it’s a brand).
There are many gas station in my city but this one is brand new:)
jimptsog
LocalitĂ : Greece
Messaggioda jimptsog » 24/03/2019, 18:10
And you put more kg cng in this gas station?
MNTDVD
LocalitĂ : Udine
Messaggioda MNTDVD » 24/03/2019, 18:17
Yep,it’s actually the best in town,a few days ago i was able to get 14,7kg,thanks to low temperatures:)
lillabu
LocalitĂ :
Messaggioda lillabu » 26/03/2019, 8:18
Ciao! Hai novitĂ  sui consumi? Sono migliorati?
Ho ordinato da poco una Excellence a metano e non vorrei brutte sorprese
Grazie!
Ultima modifica di lillabu il 26/03/2019, 10:09, modificato 1 volta in totale.
Arona Excellence TGI - Blu Mediterraneo e Grigio Magnetico
MNTDVD
LocalitĂ : Udine
Messaggioda MNTDVD » 26/03/2019, 9:25
Ciao,al momento sono un pochino migliorati,riesco a percorrere circa 300km con un pieno,ma l’autostrada (a meno di non andare tra i 110 e i 120) resta sempre il suo punto debole.
Torna a “CONSUMI Arona”
