Esatto il mirrorlink non funzionaApplicazioni per Android Auto
- Lucio1974dgl
- LocalitĂ : Bergamo
Momao24 ha scritto:Ma la funzionalitĂ ATTIVITA della app SEAT DRIVE APP,con quel grafico a pentagramma...!?
Ciao, almeno a te rende un grafico. Quando arrivo a quella videata resta inchiodato nel nulla con la scritta "elaborazione...". Magari sbaglio qualcosa io. Hai qualche dritta a riguardo?
- Momao24
- LocalitĂ : Como
Hai il NAVI PLUS?
- Momao24
- LocalitĂ : Como
Da una pagina Facebook....
Huawei NOT compatible with Android Auto
4 febbraio 2018 ·
**Temporary fixes for Android Auto/Huawei incompatibility**
*Not connecting to your head unit*
- Enable Developer Options and enable USB debugging mode.
- Connect AA while your screen is on.
- Use stock USB cable or a cable of the type ASIN B01KHM0EA6
- Disable are battery saving options for all apps connected to AA (Spotify, Waze, ...)
*Not connecting to your head unit or black screen*
- Settings
- System
- Reset
- Reset network settings
- Connect to head unit
*Black screen when connecting or starting up Waze*
- Go to settings
- Go to apps
- Select Android Auto, delete all data including cache.
- Start up Android Auto before connecting to the car and give all permissions.
- Android Auto should be working now, but you'll need to do this with every reboot.
*No sound with Google Play music (or low volume)*
- Install a third party equalizer app from the app store
- https://play.google.com/store/apps/details… has been tested and works, but can be unstable.
*No in call screen*
- Install this APK
https://www.apkmirror.com/…/google-phone-7-0-1408…/download/
- Set as default dialer.
- Enjoy AA with a working dialer screen.
- Alternatively there is this thread on XDA-Developers that offers a modded version of the Google dialer. https://forum.xda-developers.com/…/app-google-phone-v14-0-1…
*Waze crashes during phone call*
- Disable all powersaving functions for the Waze app
- In the Waze app, "Settings" > "General " > disable "Keep Waze on top"
- In the Waze app: "Settings" > "Sound and Voice" > "disable "Mute Waze during calls"
4 febbraio 2018 ·
- Settings
- System
- Reset
- Go to settings
- Go to apps
*No in call screen*
- Install this APK
- Momao24
- LocalitĂ : Como
Lucio1974dgl ha scritto:Ciao, almeno a te rende un grafico. Quando arrivo a quella videata resta inchiodato nel nulla con la scritta "elaborazione...". Magari sbaglio qualcosa io. Hai qualche dritta a riguardo?
Usi il cavo USB originario?
Che versione di Android?
Ultima modifica di Momao24 il 28/03/2019, 21:18, modificato 1 volta in totale.
Momao24, Dopo 312 messaggi commetti ancora queste infrazioni da noob??
Dai, per cortesia, riduci almeno la quotatura e ricordati di non scrivere messaggi consecutivi in futuro!!!
- LocalitĂ : Prov. di Brescia
Allora premetto che io con ľelettronica non vado molto d'accordo però con android auto collegato via usb aggiornato al 4.1 mercoledì scorso non mi da problemi ne utilizzando Google maps ne waze e se ricevo chiamate anche li problemi 0 ľunico mio problema é da gennaio che cercando nel play store non trovo più la seat drive app che avevo installato a dicembre poco dopo l a consegna delľauto ma che per altro non ha mai funzionato come anche il mirrorlink
- Momao24
- LocalitĂ : Como
Cioè....da gennaio 2019....cioè quando da Android 8.1 sei passato ad Android 9 sul tuo P20...?
Android auto ha sempre funzionato é la seat drive app che a dicembre ero riuscito ad installarla perònon ha mai funzionato ed ora se la vado a cercare nemmeno la trovo
- Momao24
- LocalitĂ : Como
Quando usavo il SAMSUNG S7EDGE con Android 7 e il MIrror Link non funzionava....avevo risolto installando l'app LG MIRROR DRIVE, che per installarla su un cellulare non LG non la puoi scaricare da Play Google, ma per esempio da qui:
https://www.apkmirror.com/apk/lgelectro ... 7-release/
Dopo averla installata, per farla funzionare su cellulari non LG, devi disabilitare le notifiche dell'app.
- Lucio1974dgl
Momao24, ho un LG-G6 aggiornato a Oreo 8,0. Il cavo che utilizzo non è originale, oggi provo a vedere se col suo cambia qualcosa e faccio sapere, anche se nutro qualche dubbio a riguardo, visto che con Android Auto non fa una piega. Magari con quello riesco a vedere anche i video, sai... le ho provate tutte, ma senza root ho idea che sarà impossibile!
- -Pelly-
- LocalitĂ : Brembio (LO)
- Auto: Ateca DSG 4Drive FR
Lucio1974dgl ha scritto:almeno a te rende un grafico. ... con la scritta "elaborazione...". Hai qualche dritta a riguardo?
il primo grafico esce dopo ever fatto un percorso, per dar modo al sistema di avere dei dati da elaborare e proporre
- Lucio1974dgl
Pelly di percorsi registrati sull'app ce n'è!
Momao24 col cavo originale mi ha dato il pentagono, ma sempre con la scritta elaborazione in corso!
Devo essere io ad essere incapace
- -Pelly-
ma quindi neanche da smartphone vedi il grafico?
- Momao24
- LocalitĂ : Como
Cosi io vedo il grafico in questione direttamente sul cellulare, per esempio .... avendo attivato il GPS sul cellulare...
